Trying to flash my Mini-Pro Strong with 7CProportion/INO file. Followed all the steps keep getting
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
Any Advice?
Thanks,
T
USBASP Problem
Tommy_Boy
Re: USBASP Problem
Thanks, did not think that the code was Loading., apparently it was!Phil_G wrote: 26 May 2019, 00:41 Hi Tommy, its not a problem, ignore it.
Some usbasps have a fixed sck so avrdude cant change it and gives this warning.
Just ignore it. Theres a more lengthy explanation in the Arduino section.
Tell us about your project, what are you converting?
Thanks a bunch!
I live near PGH. PA. I teach math, Physics and C#. Thanks for your efforts with the Arduino code! I have my Original Kraft Sport Series that my dad gave me for Christmas(Early 80's) used of course. Used it for a number of years then built an Ace Silver Seven, then later converted it to a Micropro. I was going to use the original Encoder for my update on the Kraft, but became intrigued with your code and Mini-Strong. Did not like the idea of not having servo reversing or EXPO, endpoint adjustments. Not to mention the set is 40 some years old with old caps! I purchase a Jumper 4-in-1 Module from Kool hobby flashed it with Multiprotolcal, and seems to work on DSM2 22ms. It will be great if I can get this set to work with all these updates!!
T
Re: USBASP Problem
Hi Tommy,
Welcome
. Hope all goes smoothly with the Kraft conversion - Phil's code works a treat
A tip - remember to calibrate the encoder the first time you use the Tx, otherwise in your haste/excitement, you switch on & then wonder why it's not working properly (guess why I know
). Have a good read of the encoder instructions - http://www.mccrash-racing.co.uk/sc/data ... 22019b.pdf
Welcome
